My series 2 is nearing ready for spraying i cant find on here the order of trial fitting the chrome in particular the headlight trims which im told are pop riveted can anyone point me in the right direction, ie are the pop rivets put in place and then slide the trims over them or are they fitted after spraying, Also is there a knack to hold the rubber strip in place when fixing the trims. Any advice appreciated.
series 2 headlight chromes
rubyfloriley
Topic author - Posts: 61
#2 Re: series 2 headlight chromes
You paint the car first - and then very carefully fit the chromes on top of their rubber strip.
You may find Chris Vine's blog useful on how to do it:
http://etype.chrisvine.com/
1969 Series 2 FHC
1969 Series 2 FHC
rubyfloriley
#3 Re: series 2 headlight chromes
Many thanks i will take a look.
