I have not driven the car since as I was still restoring it and had not filled the system with brake fluid.
I noticed that the reaction valve was VERY close to the engine frame and while investigating I removed the large plastic reaction valve cover.
I found a large spring behind the diaphragm and no small spring in the attachment at the front of the plastic housing.
This is the spring I found:
I found another thread on Jag Lovers where someone else had found this larger spring, but no conclusion was reached.
I have now removed this large spring and put a smaller spring in the nose of the reaction valve as per original.
I note that the spring is not included as a spare part anywhere, so I have used a generic spring.
My question is: is the small spring rate critical and has anyone ever seen a lager spring used behind the diaphragm?
Thanks,
