E-Type S1 3.8 -. Correct Engine?
SorenO
Denmark
#1 E-Type S1 3.8 -. Correct Engine?
Post by SorenO » Fri Aug 28, 2020 11:39 am
Dear all,
I am new to this forum. I have a question, I have an E-type apparently numbers matching. However changing the oil filter insert - I discovered that there are 5 holes in the engine block, and not 4 holes as shown in the parts catalogue - 5 holes is only in the enigne block for MKII and S-Type?? CAn anyone help me to clarify this?
Kind Regards
Soren O - Denmark
#2 Re: E-Type S1 3.8 -. Correct Engine?
Post by rswaffie » Fri Aug 28, 2020 11:54 am
What is the engine number stamped above the filter housing. Also, there should be a casting date on the right side of the block, above and to the right of the filter housing.
SorenO
Denmark
#3 Re: E-Type S1 3.8 -. Correct Engine?
Post by SorenO » Sat Aug 29, 2020 11:56 am
thank you for the answer engine block number is stamped on the block and is corresponding.
My doubt goes towards if the block has been changed and restamped.
#4 Re: E-Type S1 3.8 -. Correct Engine?
Post by rswaffie » Sat Aug 29, 2020 12:46 pm
You can also check the engine number on the flywheel as it should be stamped on it as well. There should be a casting date on the block. Your number suggests a late ‘62 build date so block Casting data may be around April 62.
#5 Re: E-Type S1 3.8 -. Correct Engine?
Post by PeterCrespin » Sun Aug 30, 2020 12:24 pm
rswaffie wrote: ↑
Huh? You mean the left side of the block near the dipstick?
#6 Re: E-Type S1 3.8 -. Correct Engine?
Post by rswaffie » Sun Aug 30, 2020 12:49 pm
Yes, sorry the left side of the block as Peter noted.
It’s the ‘Jaguar’ and ‘3.8’ that’s on the right side.
SorenO
Denmark
#7 Re: E-Type S1 3.8 -. Correct Engine?
Post by SorenO » Sun Aug 30, 2020 7:03 pm
Engine number is stamped and correct..
Do you know if your block has 4 or holes for the oil filter insert?
#8 Re: E-Type S1 3.8 -. Correct Engine?
Post by PeterCrespin » Mon Aug 31, 2020 11:31 am
Your block is fine. Two of three in the garage have the 5th hole and the third one probably has it too but I’m not taking the S3 XJ filter block off to check. Blocks were used in various models with/without subframes and various ancillaries.
