I finally got my car back after about 6 months - thanks Covid!
Driving in London I have the blessed speed hump issue with the S3 scraping the centre boxes when I drive over anything higher than a matchstick. Have replaced all the hanging rubbers but that didn't change much. As I now need to replace the back box anyway, I was thinking, there is quite a lot of room above the centre boxes and was considering a couple of options:
1) have a fabricator make a pair of pipes that bend upward, closer to the floor of the car for that section and back down to meet the back box pipes.
2) do away with the centre silencers completely.
3) have a fabricator make a new section with slimmer silencers but keep everything else as is
Only pitfall I can see is the extra heat from having things closer to the floor which can probably be shielded.
I don't really want the boy racer sound of removing the centre silencer, although I wouldn't mind being able to hear that V12 more.
I know theres the stainless/mild steel sound debate, but frankly the crunching of steel against tarmac is not exactly sexy.
Anyone tried any of these, or, is there a solution out there already and I'm reinventing the wheel?
