Hi Again,
I am trying in vain to pull out my headrests but they will not budge.
They are about half way out.
Are there any secret buttons, prayers or spells to extricate the or is it down to a soft hammer and brute force?
Any advice would be welcome before I end up damaging the seats.
Nigel.
Series 2 Headrest Removal -Help!
#1 Series 2 Headrest Removal -Help!
1969 E Type Series 2 2+2 Auto with Power Steering UK Registered
#2 Re: Series 2 Headrest Removal -Help!
Plenty of info on forum..search works well..viewtopic.php?f=5&t=3752&p=25292&hilit= ... 672#p25292 plus plenty more similar posts
#3 Re: Series 2 Headrest Removal -Help!
Nigel
There is a spring clip retaining the headrest. It is on one side of the chromed tube and will need to be pushed into the tube to allow the headrest to be removed.
With the seat out of the car undo the bottom of the leather seat back so you can slide your hand up inside the seat.
I used a hacksaw blade to slide under the spring clip and the headrest will then come out.
Be calm in mind before you start and be prepared for grazed knuckles.
Good luck.
Ash
Good luck.
Ash
Series 2 FHC 1970
1R 20607
1R 20607
