Speedo recalibration
#1 Speedo recalibration
I’m changing the diff on my car from 3.54 to 3.07 as such I need to recalibrate the speedo.
I know I can send the unit off and have this done but has anyone tried to do it themselves using maybe an internal speedo gearset from another model.
Just a thought - it can’t be that difficult to work on these?
#2 Re: Speedo recalibration
The speedometer and odometer are separate. The speedo has fixed gears as such and you recalibrate the speedo by moving the pointer to the correct reading - which you've previously determined by using a GPS derived speed readout on the road.
The odometer does need its gearset changing. This article is one of several "on the web" which explains what to do.
http://www.mgb-stuff.org.uk/Smith-jaege ... repair.pdf
For my change from 3.54 to 3.07 I bought an ex Mk 2 Jaguar speedo that had very close to the correct calibration for the odometer to use the gears from that.
1969 Series 2 FHC
1969 Series 2 FHC
#3 Re: Speedo recalibration
Hi Tim.....the speedo has no mechanical connection between the drive cable and the indicator needle..a spinning magnet via the cable drive draws around a cup operating the needle.....the magnets become weak and depending where you take you speedo for re calibration the magnets are re energised to give a more precise (not acurate) speed reading across the speed range......as Tom says the odometer is geared.....moveing the actual indicator needle is possible but lots of trial and error but as far as im aware only one speed will be correct where you move the needle to .........Steve
#4 Re: Speedo recalibration
I would get in touch with Speedy Cables, They recalibrated and reconditioned a few of my previous MGB Speedos when I converted them to V8 spec using a higher ratio back axle. From memory you provide them with the number of turns of the speedo cable for one turn of the back wheel and the radius of the rear tyres. I poked the speedo cable through a piece of paper with a circle drawn on it divided up into 15 Deg sectors, stuck some tape on the inner for a pointer to count the turns, while an assistant looked at the rear wheel and told me to stop after one turn. Repeated a few times on the drive to get a consistent figure.
I sent the Speedo off and it came back correctly calibrated (Speedo and Odometer) and looked like new.
Andy
Andy
Andy
1967 Series 1 4.2 OTS
Leicester, UK
Leicester, UK
#5 Re: Speedo recalibration
It really is.
As Steve says the speedo works using a magnet. The faster it spins the more deflection you get. It is possible to alter the strength of the magnet, and by trial and error arrive at the correct needle deflection for a given cable RPM. But this is not an easy process.
To correct the odometer you need to replace the gearset, and they are NLA anywhere that I could find. You could cannibalize an odometer for a 3.07 diff I suppose but if you had one to start with you'de be more sensible just to use it.
Bottom line. Send it to Speedograph Richfield in Notts.
#6 Re: Speedo recalibration
I had my speedometer recalibrated at Richfields in Nottingham. They trade as Speedograph Richfield a very prompt and good service costing £55 Plus vat and postage. I changed the ratio to 2.88 from 3.54 which has improved the touring RPM, although living in Cornwall there is a bit more gear changing on local work.
1969 e type 2+2
1932 MG Montlery replica
1936 MG TA
1954 MG TF
1969 e type 2+2
1936 MG TA
1954 MG TF
#7 Re: Speedo recalibration
Last edited by christopher storey on Tue Oct 13, 2020 11:39 am, edited 1 time in total.
#8 Re: Speedo recalibration
My 2 speedometer have been recalibrated at Richfields. Change mph for kmh and change also ratio 3.07 on the both.
Great job, communication and price.
Mich
Michel
#9 Re: Speedo recalibration
Just got my speedometer back from Richfields . Quick service, great communication and very fair price.
Tim
Tim
