Steering Wheel Motif Removal Advice?
VooDooDaddy
#1 Steering Wheel Motif Removal Advice?
Post by VooDooDaddy » Thu Nov 05, 2020 11:06 pm
Hi All,
This is my first post and I can certainly use some expert advice.
I inherited my mother's crumbling 1970 Series II FHC and I would like to remove and refurbish the steering wheel. Unfortunately, the service manuals are a little vague about removing the plastic motif.
Can anyone offer any advice on how to safely remove it without damaging it?
Here are a couple pictures. From what I understand, the central plastic part (green) should just pop out from the retaining ring (red).
- Tom -
1970 Series II FHC
Tony
#2 Re: Steering Wheel Motif Removal Advice?
Post by Tony » Fri Nov 06, 2020 1:23 am
You have to remove 3 little grub screws from behind the steering wheel boss with an Alan key. The horn boss they just lifts out. There is a spring so mind you do not lose it.
Tony (E typed)
Tony
VooDooDaddy
#3 Re: Steering Wheel Motif Removal Advice?
Post by VooDooDaddy » Fri Nov 06, 2020 1:55 am
Thanks, Tony.
I guess I should have mentioned that I had removed the grub screws per the instructions in the service manual prior to posting. (I was shocked to see that they are slotted screws! :wow: )
I'll try again to lift it out.
- Tom -
1970 Series II FHC
VooDooDaddy
#4 Re: Steering Wheel Motif Removal Advice?
Post by VooDooDaddy » Fri Nov 06, 2020 2:09 am
Okay. I got it out.
I was confused about what actually is removed. I had a steering column cross-sectional diagram and the picture from the previous post showing the back of the wheel, but nothing indicating what the "Motif" assembly actually consisted of.
- Tom -
1970 Series II FHC
