S2 IRS rebuild
288gto
Russia
#21 Re: S2 IRS rebuild
Post by 288gto » Sun Oct 18, 2020 12:48 pm
mgcjag wrote:
Sun Oct 18, 2020 12:26 pm
......note there are packing shims....Steve
I've got a few left that I had cut in stainless from an original if the OP wants them ?
Hotrod
#22 Re: S2 IRS rebuild
Post by Hotrod » Sun Dec 06, 2020 12:36 pm
Afternoon all, does anyone know where you can purchase the rear camber setting link. I cannot see it on the SNG site. Many thanks Rod
Rod Evans
1969 S2 DHC LHD
#23 Re: S2 IRS rebuild
Post by mgcjag » Sun Dec 06, 2020 1:01 pm
Hi Rod...dont know where you can buy them..but not difficult to make something up with some thin rod.....or anything like a strap so you can get the measurements as specified. ......to be quite honnest even setting camber as specified useing the links i found that once the car was back on the ground and settled it had very positive camber.....so i reset with it on the ground without links.....Steve
Hotrod
#24 Re: S2 IRS rebuild
Post by Hotrod » Mon Dec 07, 2020 6:27 pm
Many thanks again Steve
Rod Evans
1969 S2 DHC LHD
