Thank you Pete - East German Degner discovered that altering the shape of the exhaust tube on a 2stroke helped "suck" the exhaust gases out of the combustion chamber more efficiently, so helping more incoming air into the cylinder and thus allowing them to create more power. The east Germans were not pleased when he defected.
Here is a part of a fuel injection table, adjusted to strip out any difference in targeted air:fuel ratio ("AFR") and missing out any influence of the injector type. What you'd expect, is that volumetric efficiency is inversely proportional to the amount of vacuum pulled by the engine (at full throttle, i.e. wide open throttle, the mass of air getting in is twice as much as when only 50% vacuum, so you'd expect to add twice the fuel to achieve the same AFR). What this empirical analysis shows is that there are plenty of bumps and troughs in that relationship rather than a smoothly sloping surface. On top of that, the left side of the graph is between 250rpm to 1300rpm for a car with lumpy cams - the engine doesn't breathe nicely predictably at low rpm. It also implies that this can be tuned out if you have the capability to adjust these things. David (Heuer) did a similar type of analysis (but only in 2D) with the inlet trumpets on his 3.8. The numbers on the side are indicative only.
- volumetric table.png (90.56 KiB) Viewed 6740 times
