OTS Centre windscreen mirror rod screws?
Dawnpatrol
#1 OTS Centre windscreen mirror rod screws?
Post by Dawnpatrol » Mon Jan 24, 2011 10:21 am
I'm struggling to find a pair of screws that attach the boss at the top of the mirror rod to the windscreen top chrome finisher on my 1961 OTS. The Jaguar Pt numbers are BD20861/1 from plate 43-15 of the parts manual. Barrats and Robey don't do them. :shock:
Has any body a picture they could upload and or better still what the thread size is?
Anybody any experience of a good source?
Mike
Michael
1961 OTS LWE, 1965 OTS, 1966 FHC.
Dawnpatrol
#2 Problem sorted.
Post by Dawnpatrol » Tue Feb 08, 2011 12:55 pm
Managed to sort the problem my self in the end. :o
I case anybody was wondering the answer is a 2BA Pan head about 1/2 inche long. At least that is what the thread is now if it wasn't quite that before. :wink:
Michael
daverawle
#3 Re: Problem sorted.
Post by daverawle » Tue Feb 08, 2011 5:39 pm
Dawnpatrol wrote:Managed to sort the problem my self in the end. :o
Can't get to the car to check but it sounds like they may be 10-32 UNF being as 2BA is around 31 tpi and will fit fairly well. BA is mostly used with the electrics and 2BA particularly with SU carbs. I think I used 10-32 s/s pan heads for the mirror rod.
1963 OTS
1954Etype
#4 Re: Problem sorted.
Post by 1954Etype » Tue Feb 08, 2011 6:31 pm
Bit late now but David has just updated the "Knowledge Base | Technical Guides" with a spreadsheet that gives the breakdown on fasteners.
daverawle
#5 Re: Problem sorted.
Post by daverawle » Tue Feb 08, 2011 7:33 pm
That's like telling someone who doesn't know to read the instructions - how is that going to help?
1963 OTS
1954Etype
#6 Re: Problem sorted.
Post by 1954Etype » Tue Feb 08, 2011 8:49 pm
daverawle wrote:That's like telling someone who doesn't know to read the instructions - how is that going to help?
Dave, as I said, 'bit late now'......
Dawnpatrol
Post by Dawnpatrol » Sat Feb 12, 2011 6:26 pm
OK chaps, thanks for the reply anyway. As an aside if you order the 4 screws that attach the centre toggle to the hardtop from SNG, (they are listed as two different lengths in the parts manual) then you get two that fit and two that don't, thread significantly too large and both types the same length. :shock: Just a heads up if anybody else is working in the same area. I've mentioned this and a couple of other wrong items to them recently but they are low cost so not worth sending back. :roll:
Mike
Michael
Post by Heuer » Sat Feb 12, 2011 6:28 pm
For future reference here is a list of all Nuts, Bolts and Fasteners and their specifications used on the E-Type:
http://dl.dropbox.com/u/8496016/Fastener%20codes.htm
Larry Wade
#9 OTS center windshield
Post by Larry Wade » Sun Feb 13, 2011 7:17 am
Thanks David!!
That is a very useful resource.
Larry
Larry Wade
62 OTS 877842
La Canada, California, USA
