I am draining the cooling system on my S1 4.2 to refresh for the winter (1st time properly since I bought it).
rad out
header tank out etc.
List so far is:
New hoses and clips
Thermostat
Header tank.
I have a S2 Otter switch that I am going to wire to a relay with a manual override switch
Original fan and shroud (ebay/swap meet)
Stone guard (mine was missing)
question....
The drain tap on the block is stuck shut. Do I need to free it off or unscrew it?
i.e does coolant get trapped there or did it all drain out once the bottom rad hose was pulled off the water pump?
Eddie
