What are these (FHC)
vipergts
#1 What are these (FHC)
Post by vipergts » Fri Feb 18, 2011 3:29 pm
I remember taking these off on dismantling but cant think where from.
S1 4.2 FHC if that helps
Thanks in anticipation
S1 4.2 Roadster in Resale Red
Post by christopher storey » Fri Feb 18, 2011 5:46 pm
They are shims, or more accurately packing pieces, and there are two locations I can think of where they might go
1.On top of and/or underneath the central chrome pillar to which the rear quarter windows fasten
2. between the horizontal frame of the windows and the top land of the door - however these I think tend to be thinner than those
There may be other locations but at present I can't think of them
Post by Heuer » Fri Feb 18, 2011 5:49 pm
Bonnet hinge shims?
vipergts
Post by vipergts » Fri Feb 18, 2011 7:46 pm
No...Neither of those.
the center pillar ones are very thin chrome.
Door top/window frame jobbie are different size
And much to small for bonnet hinge....thats a std size envelope they're sitting on.
Keep going.....it's doing my head in
Moeregaard
Post by Moeregaard » Fri Feb 18, 2011 7:46 pm
Christopher is correct. Those are shims used to establish the correct height of the door frames on the FHC.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
paulj
Post by paulj » Fri Feb 18, 2011 8:33 pm
Hi I can agree they are from under the window frame
fit between the door top and the frame to adjust the height
vipergts
Post by vipergts » Fri Feb 18, 2011 9:18 pm
No...Listen. The shims I have for the window frames have holes that are further apart. :roll:
Why u no risten. :lol:
1954Etype
Post by 1954Etype » Fri Feb 18, 2011 9:31 pm
vipergts wrote:No...Listen. The shims I have for the window frames have holes that are further apart. :roll:
Packing pieces between window frame and top of door.
Dave K
Post by Dave K » Sat Feb 19, 2011 12:09 am
Christopher and Angus are right they are packing pieces for the door window frames.
vipergts
Post by vipergts » Sat Feb 19, 2011 9:51 am
Well something is going wrong then because I thought exactly the same....even took them up with the body and frames etc to be fitted up pre paint and they dont line up with the holes that are in the door or the frame.
The holes appear to close together
GSR 54D
Post by GSR 54D » Sat Feb 19, 2011 11:26 am
For info: my window/door frame shims/packers are single U shape and there are 6 holes on each door (series 1 FHC). Looking at these packers I would say the holes look a little too close to each other to fit my car.
John H.
Dave K
Post by Dave K » Sat Feb 19, 2011 12:20 pm
vipergts wrote:Well something is going wrong then because I thought exactly the same....even took them up with the body and frames etc to be fitted up pre paint and they dont line up with the holes that are in the door or the frame.
It doesn't say anywhere that you have to use both the holes they are only packing pieces / shims.
mystery type
Post by mystery type » Sun Feb 20, 2011 3:24 pm
your all wrong, :roll:
they should be chrome, and it looks like some letters are missing.
look out for the others... a T and a Y and a P :lol:
andrewh
Post by andrewh » Sun Feb 09, 2014 5:36 pm
Talking of the door frame shims I need some as mine have run off and hidden. They do not appear on the sng barratt website under the original part number. I know I could make some but easier to buy nice new plated ones. Anybody managed to buy these?
1962 3.8 Series One FHC
