Hi, how hard is it to replace the headlining on a series 1 2+2 ? All the cant rails and trims around the windows etc are already removed.
Replacing the headlining
Topic author - Posts: 154
#2 Re: Replacing the headlining
Steve....lots of info on the forum....try the search feature or similar topics below....Steve
#3 Re: Replacing the headlining
My Blog also covers this. Its not 'hard' per-se as long as you have removed the windscreen. Probably the hardest part is getting the glue covered headlining into the car without it sticking to anything on the way in and then lifting it up to the roof. There is not much spare material to play with.
Once you have done it you will realise its not hard - just scary :)
1964 FHC 4.2
#4 Re: Replacing the headlining
May be it can Help... (take care about the temperature with Neoprene glu)
I have slided the headliner on the two pvc tubes so i could press on the middle following the line front /rear marked on the roof and on the Head liner
It's easier all around to stick after the center already glued
Looking for a OTS 4.2 serie 1....! and now have found a fhc xk 140
#5 Re: Replacing the headlining
I agree with this approach - its essentially what I did too :)
1964 FHC 4.2
#6 Re: Replacing the headlining
Of course Chris ... i have read your blog before ...!
#7 Re: Replacing the headlining
Excellent - I am pleased my blog helped you and that you now help others
1964 FHC 4.2
