where to get the small seals between 2 brake caliper halves
johnetype
#21 Re: where to get the small seals between 2 brake caliper halves
Post by johnetype » Thu Feb 04, 2021 12:44 am
UK Muppet,
UK Muppet wrote:
Wed Feb 03, 2021 2:16 pm
As for getting calipers rebuilt for about the same as buying the parts as Johnetype suggested, I very much doubt that could be achieved, if it was possible they must rebuild them for nothing.
It cost me 70 quid to rebuild my rear calipers, including plating, 4 new pistons (standard not st/st) and new seals and I had the pleasure of doing it myself which helped relieve the lockdown boredom.
I paid £90 + VAT each for my for front callipers to be refurbished including plating and S/S pistons. I judge that to be good value for safety critical items.
1969 Series 2 FHC
Bellhelmet
#22 Re: where to get the small seals between 2 brake caliper halves
Post by Bellhelmet » Thu Mar 04, 2021 10:15 pm
Does anyone know the torque setting when reassembling the two halves of the callipers TIA
ManniB
#23 Re: where to get the small seals between 2 brake caliper halves
Post by ManniB » Fri Mar 05, 2021 8:07 am
I have used the specs below for my calipers. I can't recall where I found it and I have to reject any resposibility if you use them.
- Manfred
The torque values specified by Volvo for the P1800
calipers in 1961 were:
Tightening torque,
- inner bolts 45-50 Ib.ft. (6.2- 7 kgm)
- outer bolts 25-30 Ib.ft. (3.5-4.2 kgm)
These are ver simmilar calipers to S2 and S3, the ony
difference is a (very) small piston difference.
These must be Girling figures, otherwise Volvo would not
quote them.
I have also taken a few apart, and the only problem I ever
saw was the rust on the caliper threads which weakened the
thread.
However, I would always take them apart - the rectangular
o-ring might have decayed during lsts 40 years...
Giring part no for the o- ring is: 67320782, used by eg.
XK Unlimited.
1972 E type 2+2 Willow Green
