Steering Rack removal
colinevans
#1 Steering Rack removal
Post by colinevans » Sat Feb 06, 2021 12:45 pm
Afternoon all
Continuing with my stripdown, engine now on a trolley (out through the bottom) and front suspension removed. About to tackle the steering rack etc and stopped in my tracks by the allen key on the bottom UJ. I’ll order an imperial set but for now I presume I can undo the pinch bolt that secures the UJ to the lower column, tap it off the splines and take it away with the rack?
Colin
Colin
Series 2 OTS, 280SL
Tom W
#2 Re: Steering Rack removal
Post by Tom W » Sat Feb 06, 2021 12:51 pm
I’d avoid using a hammer on the series 2 steering column and joints. The series 2 column is collapsible, and if you’re too brutal with the hammer, you could shear the nylon pins. The steering columns aren’t available any more, and they shouldn’t be repaired after they’ve been collapsed.
But yes, if you remove the UJ from the column, you can leave it on the steering rack. Take the pinch bolt all the way out as it sits in a groove in the column, and the UJ won’t come off with it still in place.
Tom
1970 S2 FHC
colinevans
#3 Re: Steering Rack removal
Post by colinevans » Sat Feb 06, 2021 1:07 pm
Thanks Tom, would it be better waiting and leaving it until I get the allen key for the UJ? I’m thinking there’s no point taking undue risks and I’ve still got plenty of other jobs still to get on with.
Colin
Series 2 OTS, 280SL
Tom W
#4 Re: Steering Rack removal
Post by Tom W » Sat Feb 06, 2021 2:34 pm
It depends how easily the UJ moves on the splines. When I dismantled mine, it slid off without needing force.
Tom
1970 S2 FHC
colinevans
#5 Re: Steering Rack removal
Post by colinevans » Sat Feb 06, 2021 2:51 pm
Ok thanks Tom, advice appreciated.
Colin
Colin
Series 2 OTS, 280SL
Joes66
#6 Re: Steering Rack removal
Post by Joes66 » Sat Feb 06, 2021 4:57 pm
I just did mine recently
I would remove the uj completely first
Its very tricky to get the rack out through the passenger side wheel arch and there is not much room
You have to twist and turn it as you remove it
Also you cant get the uj off without also unbolting the uj in the drivers footwell and pulling the shaft up to clear the splines
Doing it this way makes it more easy to refit it all afterwards
I changed both my uj's at this point anyway
Joe
1969 series 2 2+2
colinevans
#7 Re: Steering Rack removal
Post by colinevans » Sat Feb 06, 2021 5:37 pm
Thanks Joe
My bonnet, engine and front suspension are all out of the way as its a full strip down, so plenty of room now!
Colin
Colin
Series 2 OTS, 280SL
