FHC Sliding Catches on Hinged Extension Board
Topic author - Posts: 1801
#1 FHC Sliding Catches on Hinged Extension Board
It appears that the balls and springs from my sliding catches (BD9395) have gone astray at the chrome platers. Can anybody give me any guidance on the ball diameter and spring length please?
It seems a shame to have to buy complete assemblies, especially since the new chrome is pristine.
#2 Re: FHC Sliding Catches on Hinged Extension Board
Ball Diameter 3.1mm
Spring:
wire dia. 0.3mm
spring dia 3mm
spring height 3.1mm
3.5 coils
Tadek
Spring:
wire dia. 0.3mm
spring dia 3mm
spring height 3.1mm
3.5 coils
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#3 Re: FHC Sliding Catches on Hinged Extension Board
Thank you Tadek!
I was about to start experimenting - beginning with cutting balls out of ball point pen refills.
Your information is a big help to get me going. Do you think the balls are chrome plated brass? I don't think it matters other than for correctness because the catches aren't likely to get a lot of use.
#4 Re: FHC Sliding Catches on Hinged Extension Board
You are most welcome.
Just a plain bearing ball....
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#5 Re: FHC Sliding Catches on Hinged Extension Board
And 3.1mm is probably actually 1/8".
#6 Re: FHC Sliding Catches on Hinged Extension Board
Hi Stu
I think i my be able to help .....as I think I have a pair of these catches left over..let me check and let you know...you can have them and canabalise them..as they are a tad rusty
Best
Jonathan
Best
Jonathan
#7 Re: FHC Sliding Catches on Hinged Extension Board
Thanks Jonathan
#8 Re: FHC Sliding Catches on Hinged Extension Board
This forum continues to astonish me with depth of knowledge that members jointly have and are willing to share alongside the generosity of those willing to part with items.
Long May it be so.
Tim
Long May it be so.
Tim
#9 Re: FHC Sliding Catches on Hinged Extension Board
Hi Stuart
Send me your mobile number please and I can take a couple of pictures for you to check I am talking about the correct items
Best
J
Best
J
#10 Re: FHC Sliding Catches on Hinged Extension Board
Hi Jonathan
Catches arrived on Friday, thank you.
I soaked them in penetrating oil to free them off and got them apart easily enough.
The balls are indeed 1/8" diameter as measured with my Imperial micrometer.
The springs are both different. One is 3.5 coils with one flat end and the other is just 2 coils with open ends. I have no reason to think they've ever been taken apart before now.
My luggage extension board is now complete thanks.
#11 Re: FHC Sliding Catches on Hinged Extension Board
Curious....but if they work....leave well alone and enjoy...!
