3.8 dynamo conversion
swindler
#21 Re: 3.8 dynamo conversion
Post by swindler » Wed Apr 22, 2020 11:01 pm
3.8 OTS 1964
Original RHD. Close ratio moss box
peters3103
#22 Re: 3.8 dynamo conversion
Post by peters3103 » Wed Apr 22, 2020 11:26 pm
Good news, I have mine fitted up having got the correct bracket, pulley, fan and belt however the engine won’t be back in till I’ve re-fitted the picture frame and front suspension. I note that the alternator I removed had three wires but only two wires required for the Dynamator. That confuses me but I’m easily confused!
61 E-Type FHC Opalescent Golden Sand - now sold 😕
swindler
#23 Re: 3.8 dynamo conversion
Post by swindler » Sat May 01, 2021 9:35 am
Hi all
In case anyone sees this thread the Dynamator has failed.
No support from Powerspark even though it's only 18 months and a couple of hundred miles of use.
Try elsewhere!
3.8 OTS 1964
rfs1957
#24 Re: 3.8 dynamo conversion
Post by rfs1957 » Sat May 01, 2021 3:12 pm
Yes, confusing isn't it.
Choice between either :
Powerlite - who make a dynamo-alternator called the Dynalite.
or
Powerspark - who make a dynamo-alternator called the Dynamator.
Would the cheap one, with the poor product and the poor warranty, by any chance be trying to confuse buyers by using a confusing company name and a confusing brand name ?
peters3103
#25 Re: 3.8 dynamo conversion
Post by peters3103 » Sat May 01, 2021 9:13 pm
What has happened to your Dynamator to make it fail? Interested to know as I have fitted one but only done about 1000 miles since.
swindler
#26 Re: 3.8 dynamo conversion
Post by swindler » Sun May 02, 2021 7:25 pm
Hi Pete
It started being temperamental and only suddenly charging at above 2500rpm ish
I bought a smaller pulley on advice but it made no difference
Then a bearing whine started to develop and on investigation there is White powder on the fan, and now the ignition light is on even when it’s charging so I’ve stopped using it pending fitment of a quality replacement!
M
3.8 OTS 1964
rfs1957
#27 Re: 3.8 dynamo conversion
Post by rfs1957 » Mon May 03, 2021 9:33 am
Interesting update on the situation with these.
Powerlite are now supplying Powerspark with Dynalites, as Powerspark got fed up with the 50% return rate on their "own" cheap copy, the Dynamator.
So looks like Dynalite is indeed the way to go to.
Lifetime warranty.
Michale Hadley (MD at Powerlite) answers emails, always a good sign, and stands behind his product.
MarkRado
Austria
#28 Re: 3.8 dynamo conversion
Post by MarkRado » Tue May 04, 2021 4:44 am
accuspark.co.uk still list the dynamator on their website for 180.- for the C42 pos earth (the Dynalite is 525.-)
1963 OTS 880436
#29 Re: 3.8 dynamo conversion
Post by PeterCrespin » Sat May 08, 2021 1:31 pm
rfs1957 wrote: ↑
Lifetime warranty.
Interesting. I have a very slightly-used + ve earth Powerlite E-type kit I wanted to use on the D, but it's too big for the space above the inclined engine mount. If they are guaranteed for life I feel a lot more comfortable selling it for half new price if anyone wants to PM about it.
