Luggage board pegs/pins BD10958
Topic author - Posts: 49
#1 Luggage board pegs/pins BD10958
Does any one know if the aftermarket pegs for the luggage boards are the same threads as the originals as both mine have sheared off. I have managed to remove the old thread from the washer nuts using heat so I have replace these on the board but before I recover I wanted to know the threads of these after market ones
thanks
Chris
thanks
Chris
Chris
Series 2 FHC, + C type replica
#2 Re: Luggage board pegs/pins BD10958
Hi Chris
These people stock a wide range of this sort of hardware. As well as the pins, I think they stock the captive nuts as well.
https://www.bresco.com/acatalog/Latches_and_Studs.html
I spoke to them once and they were very knowledgeable.
Also, these people may be able to help
https://www.segalmotortrimmings.net/ind ... 9:70141::0
ATB
Andy
ATB
Andy
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
1970 S2 FHC
#3 Re: Luggage board pegs/pins BD10958
Andy
thanks for the link some useful stuff there.
I might end up repairing the pin by tapping it as I have removed the sheared thread from the captive nut and replaced it back on the board, so hopefully I can continue recover my luggage board.
I had hoped someone may have had the same issue as myself and knows the answer to the original post
thanks again
Chris
thanks again
Chris
Chris
#4 Re: Luggage board pegs/pins BD10958
Hi Chris
Give Bresco a ring tomorrow. I'm positive they'll give you a definitive answer.
Andy
Andy
Andy
1970 S2 FHC
1970 S2 FHC
#5 Re: Luggage board pegs/pins BD10958
Think the originals were 2BA.......as some suppliers provide the stud and retainer as a unit they could be useind a different thread
#6 Re: Luggage board pegs/pins BD10958
Hi Chris,
the aftermarket assembly in my parts bin is from SNGB and includes a shakeproof washer and the nut. I bought it in 2018 and the thread is UNF 10-32 (3/16 UNF)
Klaus
#7 Re: Luggage board pegs/pins BD10958
Klaus, Steve
thanks for response I'll try and identify my thread hopefully its 3/16" unfortunately then I know I can use the SNGB replacement
Chris
#8 Re: Luggage board pegs/pins BD10958
Chris, I’ve got some spares in the garage ( god knows where) I’m not sure of the thread but if I can find them you can have them.
Tim
Tim
#9 Re: Luggage board pegs/pins BD10958
Shown here as 2BA thread....would look very similar to 3/16 https://www.bresco.com/acatalog/2BA-Bal ... F187P.html
#10 Re: Luggage board pegs/pins BD10958
So, some of those bits you know have but where?
Right - start the search, are they in the 2 bookshelves of spares- no
Are they in the plastic draws where I keep all the spare threaded bits, washers etc - no
Are they in the old kitchen cupboards now doing steering service for other stuff -no
Are they in the 2 plastic boxes of spare bits hidden under the bench - no
Dammit they must be somewhere
Are of course they are in the other plastic box next tins of old paint and a spare tyre for a car I no longer own.
Success!
I really must have a good clear out sometime
But of course I know where everything is !
Success!
#11 Re: Luggage board pegs/pins BD10958
Tim
You are having a clear out as I’m having bits off you
Chris
