Engine noise
Pgxxl
#1 Engine noise
Post by Pgxxl » Tue Jun 01, 2021 3:17 am
Hi guys, is it normal to have a ticking sound coming from the engine like a tappet noise. Am I being too fussy thinking my 50 year old V12 should be quiet? She runs so smooth and pulls like a train
1972 OTS
Opalescent silver blue
Purchased Oct 2020
AussieEtype
#2 Re: Engine noise
Post by AussieEtype » Tue Jun 01, 2021 5:18 am
Yes
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
#3 Re: Engine noise
Post by abowie » Tue Jun 01, 2021 5:31 am
:yeahthat:
SESH
#4 Re: Engine noise
Post by SESH » Tue Jun 01, 2021 9:10 pm
Same for me, I've been worrying about it for a few months now.
it's a tappet sound that gets louder as the engine temp increases. At cold start up you can't hear it.
I had all the tappets shimmed as well. Was concerned that something might have worked loose. Does the V12 have a valve seat that could have worked loose?
Car drives otherwise ok.
Mike
1963 Triumph TR4 Signal Red
jfmassa
#5 Re: Engine noise
Post by jfmassa » Thu Jun 03, 2021 6:47 pm
I had a similar issue that concerned me for some time. I determined that it was a cracked exhaust manifold. Replaced manifold and "ticking" ceased.
regards,
Joe
DeanW
#6 Re: Engine noise
Post by DeanW » Thu Jun 03, 2021 7:04 pm
I had a similar issue, it was a blowing exhaust manifold. Sounded as you described.
Dean
74 Series III Roadster
68 Series I FHC
89 Porsche 911 3.2 Carrera
H7OB
#7 Re: Engine noise
Post by H7OB » Thu Jun 03, 2021 8:00 pm
+1 on a cracked manifold, albeit on a 4.2.
They can sound more ‘tappety’ than you’d expect.
'68 Series 1.25 2+2
MarekH
#8 Re: Engine noise
Post by MarekH » Fri Jun 04, 2021 9:41 am
If there is a crack, you should be able to see a black line of carbon where it blows by. If running, you should also be able to feel it. It should also be quite dirty, so will stand out after a clean.
madjack4
#9 Re: Engine noise
Post by madjack4 » Sat Jun 05, 2021 10:14 pm
Hi my v12 had a ticking like a tappet,when i stripped the engine there was excessive wear on the bores a previous owner in the USA had knurled the piston skirts to take up the wear.After fitting new pistons and liners the ticking has gone,hope thats not your problem its very expensive
Rob 1972 s3 roadster
Aston Martin DB9 Volante
