Hi, does anyone have a recommendation for removing the original glue that held the headlining to the roof?
I've tried a couple of spray on removers and even cellulose thinners but it doesn't want to come off the roof
Steve series 1 2+2.
headlining glue removal
Stevejaguar
Topic author - Posts: 176
#2 Re: headlining glue removal
Hi Steve...the only thing that worked for me to remove old glue was petrol on a rag to soften it and rub it off....it does work but needs lots of effort....however.....lots of ventilation and outside only.....petrol fumes are very dangerous.....im NOT recommending you try it.....Steve
#3 Re: headlining glue removal
I've successfully removed glue residue using gun cleaner thinners. As per Steve, I don't recommend doing this in an enclosed space.
You could try sticky stuff remover, which has proved effective on removing labels and stickers.
