I have some problems with the isolation of the contacts of my distributor cap.
The insulation of the contacts in the distributor cap burns off after about 2000 km. After about 3000 km misfires start. It seems as if the spark hits the insulation before reaching the contact and slowly destroys the insulation there, i.e. the spark ignites in the direction of rotation. The pictures show it most clearly.
It is an etype S1, 2+2, year 1966, 4,2l.
Due to the Weber carburetors, which do not produce vacuum, the previous owner has installed a distributor from an XJ after Bj. 1974. This was equipped with a Pertronix Igniter 1, instead of the breaker contact.
Spark plugs, ignition coil Lucas Sport, ignition cable, plug, rotor, distributor cap all new from SNG-Barrat. (Of course matching the XJ distributor).
Ignition with ignition gun checked everything O.K.
So far I have worn four distributor caps, but despite troubleshooting found nothing.
Maybe someone here in the forum has already seen this phenomenon and has a tip....
So slowly I run out of ideas and patience and I tend to install a 123 distributor, but actually runs the Pertronix super.
Thanks in advance ...
Robert
