65 wire wheels tubeless?
jagwit
#1 65 wire wheels tubeless?
Post by jagwit » Tue Jun 15, 2021 1:20 pm
Would the wire wheels of 65 S1 XKE be tubeless or require tubes?
Best Regards
Philip
#2 Re: 65 wire wheels tubeless?
Post by Heuer » Tue Jun 15, 2021 2:22 pm
if they are original they will require tubes and rim tape. Some repro wheels are tubeless but you need to check with the manufacturer. Basically if the spoke/rim joint is sealed then you can use tubless.
