Hi guys . My series 3 has just began to stutter a little around 20k revs upwards. It’s also seems harder to start. Could it be because I have used 97 octane fuel for the first time ?
Misfire
#2 Re: Misfire
No. Perhaps fuel filter?
#3 Re: Misfire
I'm impressed you can get it to "20k revs" in the first place.
#4 Re: Misfire
Bro has an XJ12C pillarless coupe....essentially the same engine although injected...one of the plug connectors associated with ignition on top of the engine was making poor contact...similar symptoms until the wire fell off then all stop!..might be worth checking and cleaning all the connections around the opus/distributor etc...
#5 Re: Misfire
Schoolboy error Steve ♂️
1972 OTS
Opalescent silver blue
Purchased Oct 2020
Purchased Oct 2020
#6 Re: Misfire
Out of curiosity what were you using before?
Mike
1969 S2 FHC
1969 S2 FHC
#7 Re: Misfire
I have got mine to run well on 95 octane for years now,
Adam
1957 XK150 since 1976
