Marston excelsior aluminium radiator
Paul marriner
Topic author - Posts: 3
#1 Marston excelsior aluminium radiator
Hello does any body know if there’s someone in the UK who could fix a leaking Marston Excelsior aluminium radiator from a 62 E-Type kind regards paul
#2 Re: Marston excelsior aluminium radiator
i don't believe they can be economically repaired and even if it could be it is unlikely to be reliably usable on a road car. They were a very expensive item back in the day costing Jaguar £8/17/7 each but the design was flawed hence Jaguar supplied brass replacements after 3.8 production stopped. Best option is to buy one of the modern Marston replica's from Fosseway or Radtec. Not cheap but superbly made and very few people could tell the difference. They even supply the correct Marston tag or you could transfer your original over.
Paul marriner
#3 Re: Marston excelsior aluminium radiator
Yes your probably wright in what you say but I was trying to keep as original as I can thank you for your reply Regards
