SII - Clutch Alignment Tool
JC
#1 SII - Clutch Alignment Tool
Post by JC » Thu Oct 21, 2021 6:20 pm
Clearly, I need a clutch alignment tool to fit my new clutch!!
There seems to be 4 options - there are probably more!!
1. Buy a £10 generic tool, locally from a general parts dealer
2. Buy a specific 'looking' tool from say Moss - for about the same price with postage
3. Make a DIY tool using a rod and insulating tape
4. Buy an expensive, all singing, all dancing professional one
As ever, all advice will be very gratefully received!!
Cheers, John C
angelw
#2 Re: SII - Clutch Alignment Tool
Post by angelw » Thu Oct 21, 2021 7:13 pm
Hello John,
I suspect that the two in the £10.00 area are simply two diameters; the spigot journal being a reasonable fit in a 1/2" ID bush in the flywheel, the other, a close fit in the ID of the Internal Spline of the clutch plate.
I use an old First Motion Shaft, but if I had to make a simple version, for £10.00, I'd buy one off the shelf; I value my time.
#3 Re: SII - Clutch Alignment Tool
Post by abowie » Thu Oct 21, 2021 9:09 pm
You're only going to use it once. Go cheap.
