Presentation
JO-44
#1 Presentation
Post by JO-44 » Thu Oct 21, 2021 4:32 pm
Hello everyone,
Frenchie, Brittany region, I have an XKE 4.2 from 1969. For some time my brakes have been sticking hot for a short time. I noticed while browsing the forum that this is a broad topic. So I will go through all the posts dealing with the subject to try to find a solution to my problem. Thank you for all these topics covered here :studyinggray:
JO-44
1954 Jag XK120(678344)- 1969 Jag XKE 4,2(1R11489) - 2004 Jag XK8 4,2
#2 Re: Presentation
Post by Gfhug » Thu Oct 21, 2021 5:41 pm
JO-44, welcome to the best place for all things E Type. Ask questions, use the search feature and review what’s in the knowledge base and you should find your answers.
Please add your name to the signature area so we can respond using your name in a much friendlier way and add you car model as it will help people answer your questions with the relevant information. Lots of friendly help here.
#3 Re: Presentation
Post by abowie » Thu Oct 21, 2021 9:09 pm
Check your reaction valve first.
JO-44
#4 Re: Presentation
Post by JO-44 » Sat Oct 23, 2021 7:41 am
VIGNETTE XKE.jpg (107.06 KiB) Viewed 5530 times
VIGNETTE XK120.jpg (212.68 KiB) Viewed 5530 times
OK I added to the profile for better discussion.
Regarding the brakes of the 1969 XKE the translation is incomplete. No overheating of the front brakes. When I release the brake pedal, the brakes do not immediately release. I see a lot of identical issues on the forum. I continue my investigations. Good day
VIGNETTE XK8.jpg (56.08 KiB) Viewed 5530 times
JO-44
#5 Re: Presentation
Post by christopher storey » Sat Oct 23, 2021 10:03 am
If there is no overheating of the front brakes but the rears are sticking on, then the likely cause is that the rubber hose between the body and the rear suspension unit has collapsed internally . The effect of this is that the hose operates as a one-way valve, allowing pressure to be applied to the rear cylinders , but preventing it being released
JO-44
#6 Re: Presentation
Post by JO-44 » Sat Oct 23, 2021 11:32 am
Hello Christopher, and thanks for the analysis. I have already bought the replacement hose from Baratt. I'll replace that. What do you think of the Fosseway kit to more easily bleed the rear brakes?
JO-44
#7 Re: Presentation
Post by Gfhug » Sat Oct 23, 2021 12:12 pm
Jo, I have an easy bleed kit on my rear brakes and certainly find it very useful
Polse7317
#8 Re: Presentation
Post by Polse7317 » Sat Oct 23, 2021 5:33 pm
Hi JO i have a kit fosseway that i don't use anymore....PM if you are interested ?
BTW i have to search it among all my mechanic stuff :roll:
