I’m using the combined indicator / flasher / horn push from the LHD series 1.5 roadster which I’m converting to RHD. I have a new RHD loom set installed and most connections are correct for RHD instruments, switches etc. I’ve connected most of the switch wires to the correct loom attachments but I’m left with a couple of wires from the switch which I can’t find an attachment point. I cant find them ou either a series1.5 wiring diagram or a series 2 diagram. One is a light green with brown stripe which may go to a 4 way snap connector with a bunch at dark green and brown. The other is a brown wire which I assume is a “ live “ but I cant find anywhere to connect it and it’s not on any wiring diagram. It’s obviously due to me using the LHD switch on a RHD car and RHD loom so the question is where do I bring a brown “ live “ from to connect or is the brown redundant and power comes via green from the fuse block.
Any help advice appreciated as I’m struggling with this one
