@Steve
I am aware that early, later and 2+2 do all have a different front torsion bar setting tool. They vary slightly. But I also know that when using this setting tool it does not mean your front ride height will stay correct.
I had that with one of my cars, but worn torsion bars resulted in a dropping front height.
So even using the correct setting tool we all know that the below distance is not always correct.
So, what are we after? The setting tool distance or the exact ride height at the front?
However
I do have 22.5 cm at the center of the lower wishbone shaft which is in the tolerance of 22.2 +/- 0.64 cm.
And here are pics of my delivery from SNG
I have been told I would not need any spacer.
Just the springs and dampers.
I think now I still need those spacers or longer springs.
Maybe spring C18977 is to short, or even wrong.
I have some 11 mm spacers which I will now install and that might help to get more ground clearance at the IRS plate and balance the car front-rear height.
