I know one of the parts is AUC 2035 as a member had a broken one on the forum which I saw pictured here. I am not sure which carb it related to though; F, M or Back.
The centre one has two holes I believe so this could well be AUC 2035. The Front and Rear carbs seem to have a single hole at the bottom so presumably could be the same part number as each other.
The Burlen site lists a lot of different levers but does not specify their use particularly well other than generically.
All help gratefully received.
Many thanks
Chris
