Fhc window outer seals
#1 Fhc window outer seals
Hi is there an easy method of fitting the seals around the outer edge of an S1 fhc window frame and the upright quarter light frame. I just cannot seem to get the to drop in .
S1 4.2 RHD Bryan
#2 Re: Fhc window outer seals
Hello Bryan,
If you are referring to the seal in the photo below. It's a 2+2 door but process should be same. I started at the top corner & fed the rubber into the channel using some CRC silicone spray as lube to slide the rubber along.
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
https://rossjohnsonphotography.zenfolio.com/
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
#3 Re: Fhc window outer seals
I will give it a try but I have already tried grease .
S1 4.2 RHD Bryan
#4 Re: Fhc window outer seals
Try red rubber grease.
Is that seal fitted the correct way around?
