Help identifying noise
SimonBrown
Topic author - Posts: 197
#1 Help identifying noise
Can anyone help me with a noise from my Series 2 please.
After a run ( more than 15 miles), when I push the E backwards in to my garage, there is a twanging/ clicking/ ticking noise from the rear of the car as it moves. It doesn’t appear to be from the diff as it is too high pitched, and too frequent to be a uj. When cold, no noise. It almost sounds like a creaking spring, but unable to reproduce it when moving suspension.
Anyone else experienced similar.
Have hopefully attached a video of the noise
Thank you
Thank you
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
1975 Honda 400 Four
#2 Re: Help identifying noise
Guessing here maybe hand brake or brakes.
#3 Re: Help identifying noise
Sounds like a propshaft or driveshaft UJ starting to fail they take some diagnosing when they first start to wear look for rust marks around them
Rob 1972 s3 roadster
Aston Martin DB9 Volante
#4 Re: Help identifying noise
Loose or broken wheel spoke? Try running a pencil around them to see if they all make the same sound, a loose one will sound different.
Mike
1969 S2 FHC
1969 S2 FHC
#5 Re: Help identifying noise
Do you still have the mushroom shaped splashguards on the driveshafts. These frequently become misaligned and start to touch the hub carriers, and that produces a characteristic high pitched squeaking noise, which sounds to correspond closely with your description of the noise
ralphr1780
SimonBrown
#7 Re: Help identifying noise
Looked at this further and the noise appears to be coming from the gearbox.
If both rear wheels are raised, then one turned by hand the prop shaft turns and the noise clearly comes from the box.
The gearbox has always suffered the reverse idler noise when clutch pedal released but otherwise fine.
Would anyone know if it is normal to hear the gearbox when turning a road wheel by hand?
It is not audible with the engine running, only rolling (pushing) at very low speed. Worse when hot.
Also, when one road wheel is turned by hand, the opposite one turns in the same direction, I don’t think it has limited slip.
Any advice much appreciated
Simon Brown
1975 Honda 400 Four
1975 Honda 400 Four
dal2.0litrefrogeye
#8 Re: Help identifying noise
Hi both wheels turning the same way is a sure sign of having an LSD .
Have you checked the prop flange bolts to gearbox flange are not loose , they're notorious for not being tight
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#9 Re: Help identifying noise
That's what happens with an LSD. When you turn one wheel on a car without an LSD the other wheel will rotate in the opposite direction.
I don't know about the gearbox noise.
*Coincided with Darren's reply
#10 Re: Help identifying noise
I would change your gearbox oil as a starting point. Use MT90.
It may be low in oil, however the only easy way to check this is to drain it.
SimonBrown
#11 Re: Help identifying noise
Thanks all for your advice:
Discovered it must have LSD!
Have changed gearbox oil within the last 1000 miles to Redline MT-90, level okay.
My real concern is the loud clicking noise from the gearbox when pushing/rolling very slowly when hot.
Can be replicated when cold (quieter though) by turning raised wheels/prop shaft. Approx 12 clicks per rotation of prop shaft.
Appreciate your help
Simon Brown
1975 Honda 400 Four
1975 Honda 400 Four
#12 Re: Help identifying noise
Hi Simon...search here for reverse idler.......here is one thread.....have a read through it...Steve viewtopic.php?f=3&t=17922&hilit=Reverse+idler
#13 Re: Help identifying noise
How have you ascertained that?SimonBrown wrote: ↑Tue Jun 07, 2022 8:18 am
SimonBrown
#14 Re: Help identifying noise
Oil level checked using level plug.
Beginning to suspect reverse idler. Strangely, the noise in neutral when clutch pedal released, which I had always put down to reverse idler, appears to have become quieter as the clicking noise has developed.
Thank you
Thank you
Simon Brown
1975 Honda 400 Four
1975 Honda 400 Four
#15 Re: Help identifying noise
Another favourite is hand brake cable rubbing on propshaft.
Barrie
Barrie
