What is the "map light" ?
dal2.0litrefrogeye
#21 Re: What is the "map light" ?
Post by dal2.0litrefrogeye » Mon Jun 06, 2022 7:45 pm
LED strip is your friend
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#22 Re: What is the "map light" ?
Post by Gfhug » Mon Jun 06, 2022 7:51 pm
Al, I replaced my map light with a short led tube/light as the old one was broken, a fairly common problem by the sounds of it. It is much brighter and hence of value when used. Simply held in place by adhesive tape.
As for the cigar lighter, stop smoking! Being serious, is your car negative or positive earth/ground? Maybe you have a negative earth new cigar lighter which may not match your wiring harness so you’ll have to change the end fittings as appropriate. Just a thought.
Hope that helps
Bob.
#23 Re: What is the "map light" ?
Post by Bob. » Tue Jun 07, 2022 1:10 pm
Hi Al
This is how Jaguar attached the map light fitting in 1971 if that is any help.
Bob
'71 S3
mtnjag
#24 Re: What is the "map light" ?
Post by mtnjag » Sun Jun 12, 2022 2:21 pm
62 Orig fixture. There is a rivet under the bulb glass.
Layne
Car #876005, 62 OTS
gtjoey
#25 Re: What is the "map light" ?
Post by gtjoey » Sun Jun 12, 2022 3:51 pm
Yes.....Unless your going original, LED is the way.
So bright ,uses 1 /100 th the energy, nothing gets hot and you can actually see at night!
gtjoey1314
Allrand
#26 Re: What is the "map light" ?
Post by Allrand » Mon Jun 13, 2022 12:28 pm
"Being serious, is your car negative or positive earth/ground? Maybe you have a negative earth new cigar lighter which may not match your wiring harness so you’ll have to change the end fittings as appropriate. Just a thought."
Interesting thought that, my son had downloaded a lot of music onto a plug in Mp3 player which he gave me as a gift. I decided to plug into my 3.8 fhc to see if my vintage Blaaupunkt would pick it up, not thinking that the car was pos earth. Smelled hot burning & saw smoke rising from the Mp3 & hastily pulled it out. It was too hot to hold & promptly dropped it onto the floor. Fortunately no damage done to the E, but the Mp3 was cooked!
Randall Botha
