Roadster Interior mirror fixing
Monkeyfinger
#1 Roadster Interior mirror fixing
Post by Monkeyfinger » Sun Jul 03, 2022 11:49 am
I've been trying to find the correct way to fit the S2 plastic interior mirror (C28516) onto a roadster screen. My car currently has a home made bracket fitted directly below the boss at the top of the tensioning rod. This works fine, but I like to put things back to 'standard' if I can. I've seen some mention of it being glued to the screen - if that's the case, then I may leave things as they are. As you'll see from the attached photo, the boss on mine has also been drilled out to accept a bolt/nut to hold the sunvisors - I'd also like to install a standard boss with the correct screws.
Grateful if anyone has any insight or pictures of a correct factory set-up for this style of plastic mirror - I've tried, but failed to find any appropriate images online or in the forum.
#2 Re: Roadster Interior mirror fixing
Post by Gfhug » Sun Jul 03, 2022 3:35 pm
Richard, why not fit an earlier mirror from an S1? They fit to the rod correctly and aren’t the awful S2 plastic.
Just a thought, cheers.
Monkeyfinger
#3 Re: Roadster Interior mirror fixing
Post by Monkeyfinger » Sun Jul 03, 2022 4:01 pm
Thanks Geoff - since my father binned the S2 mirror and fitted an S1 item around 40 years ago, that’s what it had! I finally sourced an original Wingard plastic one a couple of years ago, which I wanted from the originality standpoint, and also because it irked me that the original had been thrown away. I still have the S1 mirror, but I really want to know how the correct one is supposed to be fitted. I don’t remember it being glued on, but maybe memory deceives me.
#4 Re: Roadster Interior mirror fixing
Post by Heuer » Sun Jul 03, 2022 4:57 pm
Glued on but NLA from SNGB:
Monkeyfinger
#5 Re: Roadster Interior mirror fixing
Post by Monkeyfinger » Sun Jul 03, 2022 5:16 pm
Thanks David, but is that definitely for OTS? If it's glued on, then it can't be mounted centrally.
#6 Re: Roadster Interior mirror fixing
Post by Heuer » Sun Jul 03, 2022 6:06 pm
Ye, of little faith!
I seem to recall it came from Pilkington with the boss already mounted centrally.
SimonBrown
#7 Re: Roadster Interior mirror fixing
Post by SimonBrown » Sun Jul 03, 2022 7:57 pm
Hi Richard,
I believe this to be correct for Series 2 OTS apart from the spread of the adhesive. I copied it from the original mounting when replacing my original screen
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
Monkeyfinger
#8 Re: Roadster Interior mirror fixing
Post by Monkeyfinger » Sun Jul 03, 2022 8:05 pm
Awesome Simon, thanks!
nefematic
#9 Re: Roadster Interior mirror fixing
Post by nefematic » Tue Jul 05, 2022 5:06 pm
Here some measurements off my OTS, when I installed a new Pilkington windshield. This is where the mount was sitting on the old windshield. It is/was not centered. It also was not the original windshield I believe, since was stamped as Royal Doulton. So the measurements might be off. My mirror had a broken adjuster, a friend made one up out of aluminium, it was before 3D printing came about.
Martin Scherz
Late S2 1970 OTS US LHD
Monkeyfinger
#10 Re: Roadster Interior mirror fixing
Post by Monkeyfinger » Mon Jul 25, 2022 11:21 am
So, I had a go at fixing the mirror to the screen. Wasn't successful using 3M VHB tape, although a firm setting glass adhesive may have been better.
Instead I designed and 3D printed a simple 2 piece clamp that mounts on the screen tension rod. Works perfectly and easily removable. Also will allow me to swap the (some say) hideous plastic mirror for the earlier versions...
