The 5 Speed is here……..
#161 Re: The 5 Speed is here……..
Thank you....Hopefully this week we get the clutch and flywheel back.
Will order new propshaft bolts from SNG tomorrow.
#162 Re: The 5 Speed is here……..
I would think by cutting the crossmember as shown and then replacing it by inverting the metal , plus adding the two pcs of metal to seal the mouse holes would make the crossmember stronger
Is’nt that what triangulation and boxing out sections is about?
#163 Re: The 5 Speed is here……..
I just received a UPS notice that the fly wheel ,clutch and pressure plate is on the way!!!!!!!!
Hopefully we can start buttoning this all up by next week :)
Yes I agree, and off the record a major restorer says to play it safe its the only way they go so there is no worry of contact or binding.
GETTING EXCITING!
GTJOEY1314
GETTING EXCITING!
GTJOEY1314
#164 Re: The 5 Speed is here……..
While waiting for the clutch
Kurt got the CType from BAT
Unreal quality!
He can drive but can’t put air in the tires
Annnnnd a 5 speed to stay on topic
Unreal quality!
#165 Re: The 5 Speed is here……..
Look at all this crap lying around
We put in booster seats for Kurt Etype race car because he is a midget
#166 Re: The 5 Speed is here……..
The British Preperation H ! Has arrived!!!!
Supposedly Guy Broad wants me to use this on the splines and pilot bearing!!!
Ok
If it squeals or the body bends it’s all their fault
All I need is the clutch and we are ready to go
Gtjoey1314
#167 Re: The 5 Speed is here……..
UPDATE....The "two day" delivery I paid for on Monday will be here hopefully by Friday!
God bless America..........
So hopefully it even shows up.
GTJOEY1314
GTJOEY1314
#168 Re: The 5 Speed is here……..
What say you?
The output flange is longer so you can just slide new prop bolts.
The Supplier added nylons but I feel
They are too shallow?
I’m going to use mine , the longer nut with more lock.
I doubt the higher nut will bind
It never has before.
#169 Re: The 5 Speed is here……..
I'd be fitting new bolts with new nylocks, not reused old ones. And I'd keep the nylons for activities inside the car.
#170 Re: The 5 Speed is here……..
My bad
I’m not using the old nut
I meant the old nut size compared to what came in the mail
The old one is deeper look close
Thanks Chris
Gtjoey1314
Thanks Chris
Gtjoey1314
#171 Re: The 5 Speed is here……..
Agreed. The deeper nut must be better.
#173 Re: The 5 Speed is here……..
I agree that those supplied nuts look too shallow. Not including the nylon insert, how many threads are there? You want at least 5 although any more than that is not particularly beneficial. Are the nuts & bolts the correct 'T' grade?
You can always check for clearance around the nuts when you get it all bolted up.
#174 Re: The 5 Speed is here……..
I agree , Supplied by SNG, I usually go grade 8 but might be overkill.
Im going back to the hardware store today for the longer nut.
GTJOEY1314
Hopefully guys the clutch assembly will be here tomorrow .
GTJOEY1314
GTJOEY1314
GTJOEY1314
#175 Re: The 5 Speed is here……..
Grade 8 is definitely not overkill. Grade 5 is lower strength than British T rating, grade 8 is slightly higher so stick with that - they're doing an extremely important job.
Remember to torque them up properly and don't lubricate them beforehand. I can't remember the size, are they 5/16" UNF or 3/8" UNF?
#176 Re: The 5 Speed is here……..
Stuart...Got it!
Chrisfell, just got the nylons....now who to put them on :)
#177 Re: The 5 Speed is here……..
#178 Re: The 5 Speed is here……..
Twas bliiiind but now can see.........
No wonder why this thread is over 6,000 views!
GTJOEY1314
GTJOEY1314
#179 Re: The 5 Speed is here……..
Prep time….
It’s so time consuming but , do it three times and all should be good . It is a jaguar you know
#180 Re: The 5 Speed is here……..
I can’t help the pictures out of order
So we wheel and chase all the threads of old lock tite
The blue standard and metric board were from the hardware store
I asked if I could buy one and they called the dealer!
Great for chasing bolts and knowing what you got!!!!
Then chased the bolts to the crank it’s all very clean and smooth.
A couple of dots of high heat red when assembling and all should be good
The torque is still 67 pounds
We shall see
