Well. Well. Well
I was not happy with the spring clips holding the throw out bearing
They seat in a center hole and a bevel behind the fork
There is only 1mm between the t/o and pressure plate so the springs are really back up support to the fork arm.
Well guess what , the repro clips are a good 3/8 th
SHORTER! Than my old ones on the pin length!
Look closely
What made me look at the old ones…..GOD only knows
So old clips went in and it’s as secure as can be
Triple check everything!!!
Note graphite black grease on the input shaft
Note left clip in picture is the good one
The straight shaft is longer
And
The indent side is SHORTER!!!!
Locks in tighter and lower and more shaft down the middle of the bearing
Make sense?
