Yes moving the brake and clutch towards the firewall is the goal.
I think I misunderstood the spline adjustment to getting just the brake and clutch pedal equal.
I thought I’d found the answer with adding a spacer to the master cylinders, which would do a similar job to adjustable pushrods. But on inspection the previous owner has already added spacers.
This has left the output of the lower master cylinder perilously cost to one of the frame rails.
Andrew I did consider adding some material to the face of the accelerator but concluded this was a solution to fix an underlying problem. I’m happy with the pedal width spacing relative to each other, a little more leg room would be nice.
I have fosseway calipers upfront and Zeus on the rear which gives a very nice pedal feel and minimal travel.
I have a suspicion that the current set up would work far better for heel and toe, if I had standard calipers front and rear the free play in them would allow a longer pedal travel.
I guess if I remove the spacers from the master cylinder the pedals will end up on the bulkhead like other photos I’ve seen.
Trevor.
