Expansion tank broken
#1 Expansion tank broken
Post by DWW » Wed Sep 21, 2022 6:19 pm
Today I decided to check my coolant level and to my astonishment I discovered signs of leaks on top of the tank. Let the engine reach working temp and the tank was like a spring splattering out coolant as the pressure increased. I am not sure what crap tank was put on there and hope the new one ordered from SNGB will fare better. In the mean time I temporarily sealed up both pin holes with the trusty JB Weld and all seems well.
#2 Re: Expansion tank broken
Post by Heuer » Thu Sep 22, 2022 9:07 am
You should get one of these:
https://cambridgemotorsport.com/61-jaguar
Not only look superb by matching the curvature of the bonnet and cam covers but will last forever! Why Jaguar spoiled the engine bay with the hideous oblong header tank I will never understand. Return the stock one to SNGB and buy the CMS one.
gtjoey
#3 Re: Expansion tank broken
Post by gtjoey » Thu Sep 22, 2022 10:13 am
That tank which Heuer knows I purchased AND
Without the Bung hole because I use an adjustable Hayden fan switch
Is a work of art!
ALL of the original style ones All of them are terrible
Good luck
#4 Re: Expansion tank broken
Post by rswaffie » Thu Sep 22, 2022 11:13 am
:yeahthat:
#5 Re: Expansion tank broken
Post by DWW » Thu Sep 22, 2022 12:31 pm
Thanks guys, I did consider Aluminium tanks most around the £500 mark which look very nice and of excellent quality but obviously require some investment. I decided to stick with the steel one for the now as it is more affordable and looks closer to the original but certainly not ruling out upgrading in the future.
1954Etype
#6 Re: Expansion tank broken
Post by 1954Etype » Thu Sep 22, 2022 1:17 pm
The last steel one I bought lasted about 9 months......
Angus 67 FHC 1E33656
61 OTS 875047
dlgis
#7 Re: Expansion tank broken
Post by dlgis » Thu Sep 22, 2022 1:20 pm
So I’m feeling confused. :wow: When there are postings about cars being sold, there seems to bit a lot of raised eyebrows over detailed parts not being identical (copies) to original, something that I would refer to as “horn push syndrome”. Doesn’t the replacement of a header tank with a shiny chrome version fit into this category ? :shrug:
Notwithstanding the fact that DWW can do what he likes with his car :lol:
Darryl
TGN
#8 Re: Expansion tank broken
Post by TGN » Thu Sep 22, 2022 1:44 pm
:yeahthat:
Trevor.
#9 Re: Expansion tank broken
Post by mgcjag » Thu Sep 22, 2022 1:59 pm
Yes funny things forums...lots of different opinions :bigrin: ....its only original once when it left the factory...Steve
#10 Re: Expansion tank broken
Post by rswaffie » Thu Sep 22, 2022 2:31 pm
It all depends on how the car is being advertised.
If it’s being sold as ‘restored to original spec’, ‘concourse restoration’ or ‘mint original’ etc etc then you can expect some raising of the eyebrows if elements have been changed/upgraded/poor replacement parts used.
Otherwise, it’s down to personal choice/taste.
#11 Re: Expansion tank broken
Post by DWW » Thu Sep 22, 2022 6:46 pm
As far as my own car is concerned, it already had quite a few upgrades (five speed, front brakes, starter, alternator, cooling etc', but kept all the original parts) so it isn't concourse nor is it as it left the factory. My only consideration is that I am not quite ready to spend that much on an expansion tank at this point in time. Incidentally I received mine today from SNGB and it looks a better quality tank than the one I had on (about four years), so we are on to a 'good' start there.
Gerry
#12 Re: Expansion tank broken
Post by Gerry » Sat Sep 24, 2022 12:08 am
Hi Danny, the first mild steel header tank I bought for my 3.8 lasted 28 yrs,present mild steel tank 3yrs so far so good.Those polished aluminium tanks do look nice though.
Regards Gerry 62 Ots Ontario Canada.
#13 Re: Expansion tank broken
Post by DWW » Sat Sep 24, 2022 12:27 pm
:yeahthat:
MdR
Netherlands
#14 Re: Expansion tank broken
Post by MdR » Mon Sep 26, 2022 9:04 am
This happened to me:
Is an 1.5 year old steel expansion tank from sngb.
I was hoping someone has some experiens with the brass expension tank.
Might be a better option.
I never considered a aluminium tank, but now I'm having doubts.
Marcel
OTS serie I '66
#15 Re: Expansion tank broken
Post by DWW » Mon Sep 26, 2022 12:49 pm
Ok, after much consideration and as per David's and Angus's recommendation I went ahead and ordered the curved polished aluminum header tank, last one they had in stock, from Cambridge Motorsport, should be with me in a day or two. Thanks for the recommendation.
#16 Re: Expansion tank broken
Post by rswaffie » Mon Sep 26, 2022 12:53 pm
Blingtastic!
Did you specify a particular pressure cap? If not, just check what they supply as from memory I think the one that came with mine was too high.
#17 Re: Expansion tank broken
Post by DWW » Mon Sep 26, 2022 1:29 pm
Thanks for the heads up, I called to enquire and they don’t supply the cap any longer for that very reason and recommend using the original.
#18 Re: Expansion tank broken
Post by DWW » Tue Sep 27, 2022 9:14 pm
The jewellery piece arrived today, looks magnificent can't wait to install it :bigrin:
gtjoey
#19 Re: Expansion tank broken
Post by gtjoey » Wed Sep 28, 2022 1:48 am
You will love it.....Welcome to the dark side.!
No leaks and quality well beyond the original or repro.
gtjoey1314
#20 Re: Expansion tank broken
Post by DWW » Wed Sep 28, 2022 2:26 am
It wasn't easy :bigrin: but in the name of peace of mind, progress and the appreciation of beauty...... :bigrin:
