Today I pulled the spark plugs just to check them since it's been a while.
Green side (Right bank - from drivers seat) seems to have the more questionable plugs 1&5 dark, 6 quite brown
The other side looks good, perhaps #1 is slightly dark.
I was reading the other threads on this, does any of this mean anything anymore?
Gaps were all at 32thou or so. I have set them now at 25thou - haven't driven it yet, runs fine, but it did already.
only one of the plugs is resisted, the other 11 are not, the leads are a total mix, a couple of 8mm leads, some unmarked and some that say resisted some don't. - Why do I get the sneaky feeling if I put this all right, the engine is going to run worse
I had a look in the dizzy and whatever the part is, pickup? was a crazy ball of brown furry rust, i've cleaned it lightly, brushed off the rust and hoovered it out, I didn't want to disturb much as I didn't want to upset anything unnecessarily. the spoked wheel also has spots of corrosion.
Getting to the point
I've ordered resisted plugs, NGK BPR6ES. I'll set to 25thou
I'll need new leads I guess. -
I have never seen dizzy internals with that much rust, the gasket under the cap is knackered, so I guess that doesn't help, but any other thoughts? Does that rusted part need replacing? Everything seems to be working just fine.
I found the tiny O-ring near the plugs after I put everything back, I didn't see it come off anything.
All this being said, the car runs really well, so, I'm also waiting for the "wasn't broke, why'd you try fixing it" monster to rear it's head.
Hopefully someone with less smooth brain than mine has an overall view?
