Master Brake/ Clutch Cylinder Aluminium Tags
#21 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I'll take a set of three too, please
3.8 OTS 1964
Original RHD. Close ratio moss box
#22 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Hi Keith,
Excellent Job. Could you put me down for three also please?
August 1961 roadster.
Clive
(Hampshire)
Clive
(Hampshire)
Clive
August 1961 Flat floor ots
#23 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Hi Keith,
I would interested in two for the brake cylinders for my May 1965 S1 FHC
1965 S1 4.2 FHC (early)
#24 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I think at a certain point the tags became plastic - it must have been between before September & December '62
886953 FHC 09 '62
887530 FHC 12 '62
886953 FHC 09 '62
887530 FHC 12 '62
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#25 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Hi - Any update on these?
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#26 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Good day,
I know found an unmolested 3.8 pedal box with all 3 labels on the master cylinder. Just to help with date and number of tags.
The date on the plastic tags says 12/62.
If nobody has an earlier date, we could as per today agree that the aluminum tags were used until 11/62.
Nice being in UK again for a couple of days.
Maikel
Maikel
#27 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Sent the guy a pm, didn’t even bother to reply.
#28 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Hi MaikelMaikel wrote: ↑Mon Oct 17, 2022 5:46 amGood day,
Maikel
That's a great find (and definitely worthy of an update within the 3.8 Factory Fit section).
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#29 Re: Master Brake/ Clutch Cylinder Aluminium Tags
All ready done!
#30 Re: Master Brake/ Clutch Cylinder Aluminium Tags
So... for those of us with post Dec '62 3.8 cars, the hunt is now on for someone who could supply replica plastic tags as opposed to the Aluminium tags. Has anyone had any success with this in the past. If not, could someone produce a template from a tag they already possess?
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#31 Re: Master Brake/ Clutch Cylinder Aluminium Tags
A 3D printer would make relatively quick work of the plastic tags if someone has a sample.
#32 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Interesting for 3 if still possible
Loïc
11/61 OTS 875987
Citroën 2cvA 1953
11/61 OTS 875987
Citroën 2cvA 1953
#33 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Geoff Allam
#34 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Another vote for a supply of plastic tags. Much larger market too. BTW those aluminium ones look great.
Geoff Allam
#35 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Thanks, just need to wait for the next opportunity the planum comes off in order to install them on the corresponding masters.
#36 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Geoff Allam wrote: ↑Wed May 24, 2023 2:50 pmAnother vote for a supply of plastic tags. Much larger market too. BTW those aluminium ones look great.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#37 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I have one sample - were they all the same?
I could arrange for printing them.
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
jaspercat10
#38 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Been trying to get a response from him on this? Is anyone else receiving anything ?
#39 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Yes, quite a while ago I received the three I asked for, they are all have different inscriptions corresponding to the masters...
#40 Re: Master Brake/ Clutch Cylinder Aluminium Tags
May 62 car...think you are way past 50 already but if not three please? Julian
