The 5 Speed is here……..
#481 Re: The 5 Speed is here……..
Post by Heuer » Tue Oct 18, 2022 10:15 am
I used the 4mm (M4) IIRC and tapped the hole accordingly but you need ones that are the same or larger than the stock self tapping screws. The thumb screws of the same size will fit into the tapped thread or you can go larger and use a tap to create a new thread.
Put a rubber washer on each thumb screw shaft to make them shake proof and they work very well. You can delete the two central screws. Opening the dash is a doddle now - no fumbling in the dark with a screwdriver.
To be fair it was George Knuckey from the US who came up with the idea and he sent me a pair. I had great difficulty getting a set over here at the time but there are lots on Amazon now.
gtjoey
#482 Re: The 5 Speed is here……..
Post by gtjoey » Tue Oct 18, 2022 10:53 am
Can I get lucky by using the same knurl as the top of the center dash?
Gtjoey1314
#483 Re: The 5 Speed is here……..
Post by Heuer » Tue Oct 18, 2022 11:00 am
Worth a try although you may need tap the existing hole to suit, otherwise no reason why not.
gtjoey
#484 Re: The 5 Speed is here……..
Post by gtjoey » Tue Oct 18, 2022 11:04 am
:bigrin:
Gtjoey
#485 Re: The 5 Speed is here……..
Post by DWW » Tue Oct 18, 2022 11:58 am
They may be too long :?:
#486 Re: The 5 Speed is here……..
Post by Heuer » Tue Oct 18, 2022 1:12 pm
gtjoey
#487 Re: The 5 Speed is here……..
Post by gtjoey » Tue Oct 18, 2022 8:16 pm
Thursday/Friday The suspension will be adjusted with coil over adjustables.
Then we button up the center console by weeks end .
Then a VERY LONG test drive and a complete wrap up.
I think the thumbscrew tip was the best tip over the last 2 months!
Stay tuned for the complete wrap up.
GTJOEY1314
#488 Re: The 5 Speed is here……..
Post by DWW » Wed Oct 19, 2022 1:11 pm
Joey, hey when you do your next test drive can you compare the speedo reading to real GPS speed, will be interesting to see the result as mine needed the speedo re calibrated with the five speed. All the best.
gtjoey
#489 Re: The 5 Speed is here……..
Post by gtjoey » Wed Oct 19, 2022 7:19 pm
Will do!
My speedo was changed because I thought I was going with a 288 rear
So mine is 10 mph off to slow
gtjoey
#490 Re: The 5 Speed is here……..
Post by gtjoey » Thu Oct 20, 2022 12:13 am
So is the Cut crank seal, modern 5 speed, Alum Rad and stainless peened over rear seals worth it?
Not one drop in the floor my friends
And not a stink of anything burning
Just wonderful!
Gtjoey1314
Allrand
#491 Re: The 5 Speed is here……..
Post by Allrand » Thu Oct 20, 2022 4:36 am
What are peened over rear seals?
Randall Botha
gtjoey
#492 Re: The 5 Speed is here……..
Post by gtjoey » Thu Oct 20, 2022 7:50 am
Modern seals for the yokes and front diff yoke
They are stainless or aluminum now
They don’t leak around the yokes when spinning or sitting still
Gtjoey1314
gtjoey
#493 Re: The 5 Speed is here……..
Post by gtjoey » Thu Oct 20, 2022 10:24 am
6am on Thursday
Last job before the console parts come in to button up the job
The new replacement factory springs and shock do not sit right
9,000 miles later I’m still an inch too high
Going with adjustable coil overs to slam it down
Rob Beeres front tortion bars and we move on!
montauk1989
#494 Re: The 5 Speed is here……..
Post by montauk1989 » Thu Oct 20, 2022 7:16 pm
Hi Joey,
Not to go too far off the track but how did you determine where to set your springs?
I've got a similar setup on my car. I've been playing around with the settings and they still "feel" a bit soft so more tweaking. Is there some specific measurement you're looking for?
This photo shows them before I moved the nuts up.
#495 Re: The 5 Speed is here……..
Post by bitsobrits » Thu Oct 20, 2022 8:39 pm
Joey,
Who makes the rear dampers you used? I like the understated black finish.
gtjoey
#496 Re: The 5 Speed is here……..
Post by gtjoey » Thu Oct 20, 2022 11:07 pm
Sorry I was so late guys
We started 5 am at Bobs shop
To complete the whole 5 speed conversion, will only enhance the ride some more
It’s all done in 5 hours!
Gaz adjustable with coil overs
Front Gaz with adjustable damper settings
Bob Beeres heavy duty upgrade torsion bars NOT racing
The rears…….measure from the shock bottom stud to the top of the adjustable collar
Do all 4 even!
You want to be around 22/23/24 wheel well
Height to floor
Set all shock even on the knob till hard!
Then turn back till you like or a bounce and a half on rebound
To hard you car will push in turns with the 5 speed!
Pm your cell phones if you need help
It really complements the 5 speed!
gtjoey
#497 Re: The 5 Speed is here……..
Post by gtjoey » Fri Oct 21, 2022 1:02 am
To follow up the
NEW. GAZ are Black not the old Electric Blue!
Much better Imho visually
Front wheel wells center lip to floor 16 1/4!
Rear wheel arch around 22ish inches to floor
It’s dropping fast in the rear as it settles in
When in 5th gear around 55/60 in hard turns there is so much torque it kicks the rear out , when the shocks are in ultra hard/ 911 Porsche mode
Back off a turn at a time YOU need rebound cushion
Again a game changer over the stock!
Gtjoey1314
Montauk 1989 use the lower stud and tape measure to to of collar edge
I think it was around 14 inches
Make all 4 even then crank up or down from there
montauk1989
#498 Re: The 5 Speed is here……..
Post by montauk1989 » Fri Oct 21, 2022 2:44 am
Thanks Joey, I'll give it a try.
gtjoey
#499 Re: The 5 Speed is here……..
Post by gtjoey » Fri Oct 21, 2022 10:42 am
Pm me anytime
Driving all DAY today to settle everything down
World of difference
Wrapping up center console this weekend
The suspension drop had
NO effect on propshaft clearance or closeness to anything even with the almost 2 inch drop!
Tires set at 30 pounds
Final alignment next week
Gtjoey1314
gtjoey
#500 Re: The 5 Speed is here……..
Post by gtjoey » Fri Oct 21, 2022 1:43 pm
It’s sitting sweet
Now 21 in rear ish
22ish in the front ishhhhhh
