Hi Harry,
Your engine is obviously ready to be reassembled, block surfaced, crankshaft rectified, new pistons etc...
All the resources you need are in the "The E-Type Knowledge Base" section. Everything is available for download to make your work easier.
Of course, the Forum's essentials will help you in case of problems. (Don't forget to research your problem first, though).
Also, check all the pages of "Serie1 / FACTORY FIT - serie 3.8l" for a reassembly according to the original. For example, the 2 aluminium arrowed parts are for a 4.2L and are not present in 1962.
Reassembling the engine is a real pleasure, the bodywork a long way...especially the adjustment of the bonnet parts and the triming. Patience is the key word for a successful restoration.
Last points, did the previous owner give you a detailed photo file of all the disassembly phases and are you going to do the job yourself ?
In all case good purchase!
Mich
