Hi all.
Does anyone have a technical drawing of the bolt pattern that mates the gearbox bell housing to the 4.2 engine block?
I’m hoping someone can save me a few hours of work as I’ll have to split my setup to take the measurements.
Thank you in advance.
R
Bell housing to 4.2 engine block technical drawing
#1 Bell housing to 4.2 engine block technical drawing
Richard. UK RHD 1970 S2 2+2 Auto.
#2 Re: Bell housing to 4.2 engine block technical drawing
Hi Rich....there is this drawing in the service manual but with no dimensions....i dont know of one with all tne measurements.....if your after a few dimensions then members may be able to measure for you it tbey have an engine, bell houseing thats out....Steve
#3 Re: Bell housing to 4.2 engine block technical drawing
Hi Rich......i have a 4.2 auto bellhouseing on the bench i could take measurements from if it helps.....Steve
#4 Re: Bell housing to 4.2 engine block technical drawing
Hi Steve,
I would be most grateful if you could do that for me.
I’m not sure if you could place the housing on a scanner or photocopier? If it’s copied in sections I could then stitch the images together, in an ‘actual size’ resolution, and work from the template to build a model in CAD.
Once I have a technical drawing and assured the measurements I’ll post it here for future members.
R
R
#5 Re: Bell housing to 4.2 engine block technical drawing
Hi Rich....how about i do a pencil rubbing on to paper then post to you?.....pm me your name and address. ....Steve
#6 Re: Bell housing to 4.2 engine block technical drawing
I will be very interested to get copy of your final drawing. Would be much appreciated thank you.
After that, I would need a drawing of the gearbox to bell housing face, location of the primary shaft and length of the bell housing.
Jerome Lunt
2008 MX-5 NC PRHT - now gone
#7 Re: Bell housing to 4.2 engine block technical drawing
Hi Jerry.....put up a seperate post.....someone may have that info and post it....im just sending auto bell to engine info.....Steve
