Dash rocker switch surround colour and rear hatch lock finish
sulzeruk
#1 Dash rocker switch surround colour and rear hatch lock finish
Post by sulzeruk » Fri Nov 11, 2022 11:37 am
I am half way through restoring all the dash parts of my 1970 2 + 2, some of the rocker switch surrounds are silvers, some are black. Only looking at pictures of 1970 cars, some seem to be silver, some seem to be black? Anyone idea what they should be?
Also the rear hatch assebly lock seems to be a funny white colour, were these cadmium plated when new?
Thanks, Alasdair
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
Monkeyfinger
#2 Re: Dash rocker switch surround colour and rear hatch lock finish
Post by Monkeyfinger » Fri Nov 11, 2022 12:40 pm
The Series 2 switch surrounds should be silver as far as I am aware - if they are black, it's probably just down to wear. They can be easily painted with a fine brush and silver paint (and a steady hand)
Simon P
#3 Re: Dash rocker switch surround colour and rear hatch lock finish
Post by Simon P » Fri Nov 11, 2022 12:50 pm
Same as Richard, I've only ever seen them in silver - Tamiya Flat Aluminium is your friend when it comes to touching then up (the original paint wears and chips very easily).
The rear hatch lock was always a bit of a scruffy affair that again marks up very easily. To my eye they look like bare unfinished aluminium, which probably suggests they were cadmium plated.
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
sulzeruk
#4 Re: Dash rocker switch surround colour and rear hatch lock finish
Post by sulzeruk » Sat Nov 12, 2022 12:36 pm
Many thanks Simon, I'll get some Tamiya paint ordered up. I have stripped the back lock and escutcheon so away for plating now.
Alasdair
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
E703SU
#5 Re: Dash rocker switch surround colour and rear hatch lock finish
Post by E703SU » Sat Nov 12, 2022 3:35 pm
Simon P wrote: ↑
Simon, Does the Tamiya paint blend in well with the original paint if only part of a rocker switch surround needs restoration, or if just a few but not all of the switch surrounds need full restoration? Also any helpful hints on how to brush the paint on the surround so that it looks right (besides not downing a pint before painting :bigrin:)? Thx
Guido
1970 OTS LHD
#6 Re: Dash rocker switch surround colour and rear hatch lock finish
Post by Gfhug » Sat Nov 12, 2022 5:44 pm
Guido, get a thin brush, maybe oo size.
Simon P
#7 Re: Dash rocker switch surround colour and rear hatch lock finish
Post by Simon P » Sat Nov 12, 2022 7:05 pm
Hi Guido
Yes, it blends in very nicely. As Geoff says, all you really need is a fine artists' brush and a steady hand. It's also a good idea to thin the paint a little with some acrylic thinners before you use it so that it flows from the brush more easily.
E703SU
#8 Re: Dash rocker switch surround colour and rear hatch lock finish
Post by E703SU » Sun Nov 13, 2022 12:41 am
Geoff/Simon -- thanks for the helpful suggestions. Sounds like an easy and satisfying winter project.
Guido
1970 OTS LHD
