My IRS was fully rebuilt and fitted to the car before i bought it. The 2 rear wheels are fouling the inner arches quite badly when fitted. There are 205/70s fitted to the car at present. Any basic things to check on the IRS before I haul it out for a look and check?
Thanks, Alasdair
rear wheels rubbing on inner arches
#1 rear wheels rubbing on inner arches
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
1965 S1
1966 S1 2+2
1965 TR4A
#2 Re: rear wheels rubbing on inner arches
Inner arches or bump stops......Have a look here...your tyres are wider that Jag spec.....Steve viewtopic.php?f=3&t=19414&p=157793&hili ... ps#p157793
#3 Re: rear wheels rubbing on inner arches
You say 205s are fitted at present, if you’ve any plan to change them, why not fit the correct 185s? You’ll not regret it.
#4 Re: rear wheels rubbing on inner arches
Hi Geoff, the wheels will be replaced with a shiny new set of MWS wheels and the correct 185 tyres. I had a browse of the forum earlier and see the 185 original size is the one to go for.
Alasdair
Alasdair
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
1965 S1
1966 S1 2+2
1965 TR4A
#5 Re: rear wheels rubbing on inner arches
1965 S1 4.2 FHC (early)
#6 Re: rear wheels rubbing on inner arches
I have a scabby set of original curly hub wire wheels and ancient Pirelli cross ply white wall tyres that you are welcome to borrow until your new ones arrive. I wouldn't take them out on the road though.
Might make sense if you are somewhere in the Cheshire/Shropshire area.
