Can any kind soul who has carried out just this operation let me in on how they did it please?
[/URL]
[/URL]
[/URL]
[/URL]| Link: | |
Thanks Steve, I am fitting the original springs as I have been told the ride is very hard with the shorter springs. I will ask SNGB to measure up the springs they offer. Slightly negates my reason for buying the adjustable shockers to adjust my ride height with the original springs!mgcjag wrote: ↑Fri Feb 24, 2023 12:42 pmHi Andrew....are you fitting your original Springs.......the adjustable platform shocks iv fitted needed the shorter springs made to be used with the adjustable platform shocks. .....Steve https://www.sngbarratt.com/English/#/UK ... dbadaf5018
Thanks Jonathon, thats how I normally do it, but as the lock cap is larger than the hole in the disc it will not allow you to remove the disc afterwards!!
Ok interesting. SNGB don't know that then! They tell me that their spring is standard length and the GAZ ones are 8 inches which is obviously shorter. They also tell me that well known Jag restorer always fits the standard springs. ummm not getting anyway fast on this one! I will get them to measure their springs again.mgcjag wrote: ↑Fri Feb 24, 2023 1:50 pmInfo is in the link i posted 275lb 8in.....your new adjustable shocks arnt designed for original springs...you will sit far too high even with the platform fully down. ...Steve NB..SNG Sell two different springs for these shocks....the ones i posted and the same length but stiffer for fast road/race
Thanks very much Steve, thats a great offer. I am just trying to work out whether I need to buy the GAZ springs or not . It seems I may need to! Will be in touch if I think I Can get away with my original spring.Series1 Stu wrote: ↑Fri Feb 24, 2023 2:08 pmI had these made to help me fit my springs to Gaz dampers (non-adjustable platform). It worked well but you need to ensure you tighten them evenly.
If I can find them, you're welcome to borrow them for as long as it takes.
I need a contact in tech then! I am thinking I should just buy the GAZ springs, but not sure whether it will make it bounce down the road. They suggest that its for fast road or track. I just want a nice ride with correct ride height, thats all, cant be that tricky!!!!mgcjag wrote: ↑Fri Feb 24, 2023 2:35 pmHi Andrew....I first brought this up ages ago on the forum and with The tech department at SNGB......when fitting standard springs to the agjustable platform Gaz and the ride height being way too high.......SNGB had these fitted on their test car 50EE......when we discussed why their car was riding correct it then became obvious that they were useing the correct shorter spring.......Im assuming that the Adjustable platform shock is the same now as then and that they havent been altered in some way.......but its fairly obvious that useing original springs with the much thicker adjustable lower platform will increase the ride height......make sure you talk to the tech team and not the sales staff.......Steve
These don't look to be anywhere near safe imho. Take a look at how coarse the threads are on a commercial product and how thick the metal is. Ask yourself why that might be....Series1 Stu wrote: ↑Fri Feb 24, 2023 2:08 pmI had these made to help me fit my spring.......you're welcome to borrow them for as long as it takes.
Thanks David. I am just trying to establish if I need the shorter springs on the Gaz. . If my brain is working correctly, unless I have reasonable ability to lower the platform then I cannot drop my ride height and since original springs would necessitate the lower platform being at the lowest level, I would not have any adjustment to lower the ride height. Ergo shorter springs required!!Heuer wrote: ↑Fri Feb 24, 2023 3:39 pmTake them to a motorcycle repair shop. They will have a powered spring compressor that fits the E-Type rear shocks. Basically they are the same diameter as many m/c shocks. A local shop did mine in a matter of minutes - gave the guy a tenner and he seemed very happy!
Don't worry about it Marek. Those are M12 grade 8.8 screws with matching grade 8 nuts. Since the nut has sufficient thread engagement to ensure the thread will not strip before the screw fails, and the permissible tensile load on the screw is around 36kN (or around 3.6 Tonnes), then the threads are unlikely to fail when compressing a spring rated at around 300lb/inch (52N/mm) by around 2 inches. Even if compressing 2.5" (63.5mm) the 2 screw threads would share a load of around 3.3kN - 1.65kN each. Well within the strength rating of the threads.
