E type 1962 series 1 under dash trim
#1 E type 1962 series 1 under dash trim
Hi, i have a series 1 flat floor which i am re trimming. Unfortunately, when i bought the car, all the under dash millboard, hardura etc was missing. I have now purchased this and wondered if anyone could let me have clear detailed photographs from under their dashboard of the pieces, which order they go, where they go and where/ how the fixings go. Thank you.
#2 Re: E type 1962 series 1 under dash trim
Hi...have you looked through the S1 3.8 factory fit section.....lots on info and photos there....Steve
#3 Re: E type 1962 series 1 under dash trim
From the Forum Knowledge Base:
S1 Under dash panel template l/h: https://www.dropbox.com/s/ubk7e4s1h8vj8 ... n.pdf?dl=1
S1 Under dash panel template r/h: https://www.dropbox.com/s/p48pfdrumjczp ... n.pdf?dl=1
#4 Re: E type 1962 series 1 under dash trim
My S1 flat floor has aluminum under dash trim panels upholstered with vinyl. I believe that was original for the early cars. This car was orig when purchased.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#5 Re: E type 1962 series 1 under dash trim
Thank you evryone who responded. I will take a look now. The aluminium panels i have bought are covered too. It does make me wonder what people do with their cars to lose pieces like this.
#6 Re: E type 1962 series 1 under dash trim
Yep, mine were missing on my 64 3.8 too. I can't see how the driver's side can be anything but aliminium because it has to be bent to match the shape of the dash panel at the steering collumn.
Randall Botha
