What Gearbox oil - Manual
Deano1300
#1 What Gearbox oil - Manual
Post by Deano1300 » Sun Apr 02, 2023 6:46 pm
Hello fellow enthusiasts,
Just looking for a sanity check as to what gearbox oil I should be using for a manual box Series 3. I’m looking to order Castrol Transmax Manual EP 80W-90 GL4. Is this the correct oil? Thanks in advance.
Dean
Series 3 2+2
#2 Re: What Gearbox oil - Manual
Post by Gfhug » Sun Apr 02, 2023 7:12 pm
Quite a few of us use Redline MT90. If you search for these you’ll see very positive views.
Deano1300
#3 Re: What Gearbox oil - Manual
Post by Deano1300 » Mon Apr 03, 2023 1:55 pm
Gfhug wrote: ↑
Thanks Geoff, I’m trying to ascertain whether the Castrol EP 80W 90 GL4 is suitable? Thanks
#4 Re: What Gearbox oil - Manual
Post by mgcjag » Mon Apr 03, 2023 4:23 pm
S3 Service manual has EP90 for a manual gearbox.....thats assuming you have an original type box.....service manual is a vital tool....it tells you everything about your car......Steve
Deano1300
#5 Re: What Gearbox oil - Manual
Post by Deano1300 » Mon Apr 03, 2023 4:52 pm
mgcjag wrote: ↑
Thanks Steve, Looks like I’ve ordered the wrong oil then so will order the EP90 instead. Many thanks. Much appreciated.
#6 Re: What Gearbox oil - Manual
Post by abowie » Mon Apr 03, 2023 11:52 pm
If you are not satisfied with your gearbox with the Castrol oil, give the Redline MT90 a go.
I am usually a complete non believer when it comes to one oil being better than another but the MT90 definitely improves the Jaguar box.
angelw
#7 Re: What Gearbox oil - Manual
Post by angelw » Tue Apr 04, 2023 12:08 pm
Hello Andrew,
In particular for the synchromesh gearbox, the type of oil is quite important. EP additive is important for lubricating the teeth of the gear but too high a level will affect the grip of the balk rings of the synchro hubs and can result in notchy gear changes.
#8 Re: What Gearbox oil - Manual
Post by abowie » Wed Apr 05, 2023 8:47 am
angelw wrote: ↑
Hello Andrew,
Yes I've got you there Bill. You do need to use the correct oil for the job.
I'm just not an "oils ain't oils" kinda guy.
