FHC fuel line to carbs
autoalain
#1 FHC fuel line to carbs
Post by autoalain » Thu May 18, 2023 11:13 am
Well in my basket of parts I'm missing the fuel line, from filter to carbs , prefer not to use the black rubber fuel line at this
section, would not "look" stock, the hardware stores sell a clear plastic line with reinforcement inside
the line, not just the clear plastic line, has anyone tried this approach?? Yes, could buy from Moss but
my cost to my door is $125.00 canadian funds for 2 feet of hose, a little crazy, got to cut cost somewhere
on this restore. guess I could go steel, my last option. Thanks Mike. 4.2 series 1.5
mxke
#2 Re: FHC fuel line to carbs
Post by mxke » Thu May 18, 2023 3:21 pm
Hi Mike
Tygon fuel line from aircraftspruce.ca
I can dig up the specifics if you need it.
Mike
Allrand
#3 Re: FHC fuel line to carbs
Post by Allrand » Fri May 19, 2023 9:55 am
Nylon line should be obtainable from hydraulic supply companies, had no problem in South Africa.
Randall Botha
