On my 65 4.2L the engine starts fine then runs ok for a few miles (5/7 approx) then starts to die when i begin to rev te engine closer to 3500 Rpm...sometimes it restarts as I downshift trough the gears...sometimes it just dies and I have to stop on the roadide for a few minutes before it starts again and run fine for another few miles before it cuts again.
I suspect a fuel feeding problem so I'm going to check the fuel feeding elements to see what's going on.
Your inputs will be greatly appreciated as go through this !
Here is suspect number 1 on my list, the fuel filter :
Wow it looks ugly in here !
From what I see in the filter, I'm going to check what's going on in the fuel tank !
However what's the good set up (stock or upgraded) for fuel filtering on an Etype ?
Thanks for your help !
Olivier
