Dashboard top removal
Duncjohnston
Topic author - Posts: 8
#1 Dashboard top removal
Has anybody removed just the top of the series 3 dashboard as I need access to the flasher units located next to the glovebox on a LHD USA spec with air con blocking access under the glovebox.
Series 3 USA spec LHD 1972 FHC
#2 Re: Dashboard top removal
Yes you can just remove the dash top.....drop down the center instrument panel to access fixings and far left and right corner there is a fixings....service manual is your friend.....Steve
